Air recirculate button stuck
The air recirculation button on my non a/c 85.5 is stuck in the "in" position, which I assume is full recirculate - so no fresh air coming in. Is there any way to remove the switch from the heater control panel and attempt to free it?
Old 01-25-2021, 08:25 PM
Nope. It would be easier to remove/manually open the flap that closes the air intake under the hood.
Good luck, George Beuselinck
Old 01-26-2021, 06:12 AM
In the Fires of Hell.....
kdjones2000's Avatar
The switch would need to be desoldered from the unit, after tearing it apart.
I would try a touch of silicone spray on it and see if that loosens it up...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 01-26-2021, 07:01 AM
