Can’t find oe part need help on useable replacement
I am trying to find a useable replacement for number 6 and 6a. The description simply says cap screw and cap screw, but this cap screw actually adjusts air fuel mixture doesn’t it? Anyway, any help in the right direction would be great. Right now I have a random screw and o ring on there but if this is an adjustment and not just a cap I assume I need the right parts not just what I threw together. Thanks
Old 02-15-2021, 05:00 AM
Do you have the old one to show us, or is it missing? That would tell us if it's a basic screw or something special. If the latter, I'd think it would be common to any early K-jet car, so if you happen to have a shop or yard nearby that might possibly have late 70's/early 80's VW's, Audi's etc for picking, that could be a possibility. Best bet: for anything K-jet/early 924 related like this, I'd be also be asking on the 924board.org. If you strike out there, you might try Einmalig in Huntingdon Beach, but if they have it, prepare to lose a kidney in exchange.
best of luck to you,
John.
82 911SC coupe
Old 02-15-2021, 06:18 AM
I'm pretty sure that's the plug for the air metering plate adjustment screw. If you look in the hole and see a little allen head or similar adjuster, that's what it is (do not mess with the adjuster).
All you need to do is find a little bolt that screws into the threaded hole ok, and put a little o-ring on it so it seals (important that air only gets into the system via the metering plate) and you should be good.
Old 02-15-2021, 04:41 PM
