Send a message via AIM to AJM944
Arrow Semi loud Tick..Tick..Tick...
I just acquired a semi-loud tick when the engine is at idle, the sound increases as the engine’s RPM go up.
Items to note:
** It is coming from the top half of the engine.
** Power has NOT decreased. (Nervous to drive it)
** I just changed my Oil.
** Oil pressure is up. (A good thing)
Any thoughts?
AJ
Old 04-24-2003, 10:22 AM
overkill's Avatar
Send a message via AIM to overkill
A loud ticking after an oil change? Well, the most common LOUD ticking from the top end of the engine is the lifters. They should quiet out through time. dont know why they would be ticking after an oil change though. You put enouh oil in the car? What weight you use? Another common ticking would be the injectors but they usually dont get louder with the rpms. They usually fade out with high rpms due to engine noise.
{1987}944S - (SOLD).
Old 04-24-2003, 10:31 AM
andrewgoh's Avatar
Old 04-24-2003, 11:03 AM
andrewgoh's Avatar
I do recall reading somewhere......someone said to check the pressure relief valve.....when the run is started from cold....the oil is running thick...and if the relief valve is not working properly.....this makes the hydraulic lifters a little "sticky"......until the engine warms up.....an oil becomes more viscous.....and the "stickiness" goes away......and engine runs more smoothly.....
AJM, another question.....did you happen to use a different grade of oil uring the oil change? What was the previous and current grade of oil?
least common denominator
scottmandue's Avatar
Are you sure it is not the injectors? They do make a ticking sound.
You may try a cardboard tube to listen and see if the sound is coming from the valve cover or the injectors.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 04-24-2003, 12:43 PM
Sideshow's Avatar
I had this same proplem so I took it to the shop and they laugh at me because it was my injectors. They are loud on a 944.
1983 911sc
1997 Prelude
Old 04-24-2003, 03:09 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Or you can use a screwdriver. hold the business end on the inj, the other end on your ear. Does the noise go away when it warms up? do a comp. check.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 04-24-2003, 03:14 PM
Roger Hall's Avatar
If you can hear it with the hood closed its probably not an injector. Stuck lifters can be more of a clacking than a ticking.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 04-24-2003, 04:50 PM
Thank you everyone, After reading all of the postings I got in the car and drove her down the street, by the time I got to Dunkin Donuts for my coffee, the noise went away!
Now I can hear the lifters at their normal noise levle.
I will say, it did freak me out!
Thanks again !!
AJ
Old 04-25-2003, 11:41 AM
overkill's Avatar
Dude, you should barely be able to hear your lifter and very much hear your injectors.
Old 04-25-2003, 11:47 AM
haha thanks overkill, I have that backwards!
AJ
Old 04-25-2003, 02:53 PM
944ThatCould's Avatar
Send a message via AIM to 944ThatCould
Time to let your little brother out of the trunk.
Old 05-04-2003, 09:43 PM
AFJuvat's Avatar
Would suggest running a bottle of "motor flush" through the engine right before your next oil change.
Follow directions on the label exactly.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-04-2003, 11:25 PM
todwic's Avatar
It couldn't hurt to pull out your 710 pressure relief valve and see if there is any scuffing. if there is, smooth it out with emery paper.
'86 951
Old 05-05-2003, 01:59 AM
MrPants's Avatar
where is the pressure relief valve?
it releives pressure from the oil system?
84 944 Non Alcoholic
Old 05-05-2003, 02:34 AM
todwic's Avatar
it's in the oil cooler housing. 17mm bolt.
'86 951
Old 05-05-2003, 10:00 AM
