perfecto951's Avatar
Send a message via AIM to perfecto951
My 951 shakes violently!
Ever since I bought my car back in January it has been shaking like crazy. Mainly it's at idle. The steering wheel is the worst, followed by the seats and the mirrors. The car feels like a giant vibrating back massager (which is normally nice) but not while you are trying to drive. When I raise the RPM's the shaking (for the most part) goes away...unless I’m accelerating hard, then it's the driveline somewhere else vibrating, but that’s not the problem I’m trying to solve right now. I took it to the shop, the timing was off a few degrees and the balance shafts and belts were replaced and the motor mounts were checked. So all that's in order. I just can't figure it out. Any suggestions?
1986 951, India Red. (Mine) - Not For Sale Anymore
1987 944, Alpine White. (Bother's)
2000 Audi A6 2.7 Biturbo Melange (Mom's)
Old 05-05-2003, 05:37 AM
AFJuvat's Avatar
either your motor mounts are shot, or your balance shafts were out of alignment when the belts were replaced.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-05-2003, 05:42 AM
overkill's Avatar
Send a message via AIM to overkill
I'm all for the balance shafts
{1987}944S - (SOLD).
Old 05-05-2003, 06:43 AM
coupe's Avatar
Mine is pretty much the same. It gets worse when it warms up. It could be a number of things. Idle control valve, vaccum leaks after the air flow meter, dirty injectors just to name a few.
I'm still looking to solve my shakes and vibes at idle.
I have done loads, including motor mounts, injectors cleaned, belts and pump, exhaust leaks. Still no success.
coupe
http://www.p-caronline.com/directory/coupe
Porsche 944 Turbo, 1986
Fiat Coupe 20v Turbo, 1997
Old 05-05-2003, 08:00 AM
gearhead290's Avatar
Send a message via AIM to gearhead290
Try giving it less caffein.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 05-05-2003, 10:39 AM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
My money is on the balance shafts.
If at idle shakes like h*ll and the higher the rpm the
less shake it is the B-Shafts.
Get it looked at quick. Don't need to kill kittens.
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 05-05-2003, 12:34 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Id have another look at the balance shafts like AF mentioned, Was this a reputable shop you took it to? Also there is a tendancy for some people to put the balance shafts at 180 off.
You said idle but what happens when the car is moving down the road?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 05-05-2003, 11:03 PM
