Died, then re-started...where do I begin?
Hi all, I have a 1990 944 S2 Cab which I have had for 2 1/2 years. Zero problems until last week. I was 7 minutes from home driving normal at 60 mph when the engine died completely. As I coasted for about 1/4 mile, it still was dead until I came to a complete stop, and would not re-start. Being that I am in the country without cell coverage, I was concerned. Looking under the hood nothing stood out as a problem, and after waiting about 15 minutes, I tried starting it at which time it fired up completely normal. I got my butt home, parked it until today. I started it up (perfect) and let it run for an hour without any hickups.
My question is where do I start looking as a problem without randomly replacing parts. Yes, I would like it to die again so the problem would show itself, but until then I am sceptical to take it out for a drive. Remember... I have no phone coverage for miles around here. Thanks |
I would check to make sure all the ground cables are connected in their appropriate places and wires are not frayed. Seems to be very odd it died then started again with no issue, and I know the paranoia an intermittent no start issue can cause.
Here is a link to our "How To" Tech Articles for your chassis which may help with troubleshooting. |
A DME Relay … assumes 968 has one? Others will need to confirm.
John |
944 addict
A lot of us carry a spare DME relay as a matter of course.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Yes, they can. You can also open the relay and check the contacts for signs of burning or pitted points.
As an emergency option, you can build yourself a DME relay bypass for about 10 cents, with two pieces of wire and three crimp connectors. You can use the bypass to get the car running in order to make it home if your relay dies on a trip. I carry one in each of my 944 cars.
Good luck, George Beuselinck |
I should say: It's been ordered and on the way. Last edited by Mike VS; 07-06-2021 at 01:49 PM.. |
In the Fires of Hell.....
It may also be due to a marginal speed/reference sensor.
I know a friend with an '89 NA that it would just die and after the engine cooled off it would start right up again. Had a sensor that was going bad.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
I would start here:
DME Relay Information and Testing Common for DME relays to work fine when cold but then stall the car out when it gets warm not allowing for restart until the car (relay) cools down. Highly recommend getting a solid state relay from F9 tech, for peace of mind into the future more than anything.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP |
