85.5 hard ride
Question : 85.5 944 shocks, is this correct. Front shocks are hyd and rear are gas, my 944 seems very tight in the front, allmost to the point where one person can bearly move the the front down by pushing on one side. As the back seem to move a lot easyer.
both set of shock are not that old, but it really is very hard in the front. I have checked to see if they are bent, binding or if they are on the stops. When driving they are that hard that it seems like they are on the stop rubbers. What sort of movement have you guys got in the front.
Old 05-10-2003, 04:10 AM
Send a message via AIM to TheCooler
I can move mine down a few inches in the front then it comes back up with no bounce. They arent as tight as you are saying though. The ones on the back are a little more loose and have a little bounce but still good.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 05-10-2003, 11:20 AM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
I have none in the front and I just replaced the struts,ball joints and springs(250lb). Its as hard as a rock. -chris
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 05-10-2003, 11:49 AM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Just went out to feel mine With about the same force, pushing on the top of the fender, I can get the front to compress about 1/2 inch, and the rear to compress around 1 inch.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 05-10-2003, 01:23 PM
thanks guys, i think its time to pull the conies and soften the ride abit.
car had been sitting for two years before i got it, i think they might be binding. I was quoted $490 for the front and back in monro sports.
Thanks for checking.
Regards Roger
Euro 1985.5 944 Auto
imported from USA
Old 05-12-2003, 04:17 AM
AFJuvat's Avatar
The 944 is a pretty stiff car - almost to the point of being a bit harsh.
In all honesty, you are probably due - the stock Sachs\Boge provide a good balance between handling and comfort
pretty inexpensive too
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-12-2003, 04:56 AM
Thanks AF Juvat, will look into them.
Regards Roger
imported from USA
Old 05-12-2003, 06:16 AM
