Wet carpet
I'm getting wet carpet and floor mat on front friver's side. Any thoughts? Thanks in advance.
Old 11-24-2000, 01:24 PM
Send a message via ICQ to diannone
check with your doctor about bladder control? :-)
Old 11-24-2000, 03:00 PM
david944's Avatar
check the drain holes in the upper tray, mine clog all the time.
Old 11-24-2000, 03:38 PM
smell it, if it smells like antifreeze (kinda sweet and sticky) then say "F**K ME" and replace the heater core.
if it's water then check the base of the windshield and the tray that the other guy mentioned..
Originally posted by mideastmafia:
hahahahahaha
SHAUN
Old 11-27-2000, 11:56 AM
hoff944's Avatar
Send a message via AIM to hoff944
Forget the doctor. Go with Depends! They're cheaper.
Old 11-28-2000, 07:26 AM
Im sure that it is the drain under your hood. There are two drain holes, one on each side. They often become clogged with leaves and other debris since there is nothing stopping it from falling under the hood once it hits your windshield. The drain on the passenger side is located under the battery and is not visible unless the battery is removed. If you park outside often or under trees, I recommend cleaning the drains out evry 6 months. I stick a hanger down to try and losen any stuck leaves/dirt etc. Then I pour a little vinegar down to help clear the drain tubes out. Then I rinse with a light stream of water. Hope this helps.
Old 12-01-2000, 01:32 PM
