fuel leak at pressure damper
I have a fuel leak on the fuel line that attaches to the pressure damper. Does anyone have a fix or can tell me where I can get the hose and fittings. I can't even find that part on any web site.
Old 05-19-2003, 08:21 PM
AFJuvat's Avatar
Let me guess, leaking at the swegged fitting?
Dealer only part. Not sure what year you have, however, that fuel line has been supersceded by the factory. It is now a three piece line.
Reason: You have to partially drop the rear suspension to get that fuel line out.
Trace that fuel line back to the tank, at about the middle of the car, if it has ben updated, you will see a coupling where it attaches to the hose going to the tank.
You can try taking the car to a place that makes custom fuel lines - they may be able to tighten the swegged fitting on the car.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-19-2003, 11:58 PM
Speed Force Racing sells braided stainless fuel lines to replace the leaky OEM ones.
Old 05-20-2003, 03:22 PM
I ordered a set of the speedforce lines today. thanks very much for the info
Old 05-21-2003, 07:52 PM
