Key bites, would not turn to start
The key goes in but would not turn to start the engine. Is it the locking mechanism? Can it be fixed or I need a new one with a key?
Sometimes I have similar issues with my car as the key is worn. Just playing with it seems to do the trick. Does your key work fine in the door, hatch, and glovebox?
Also ensure that you're steering wheel is not locked. A you know, a locked steering wheel will prevent the ignition lock cylinder from turning. |
Your ignition lock is worn out. If the key work in the door and hatch, the key is good.
The lock needs to be replaced. |
A locksmith might be able to replace the worn tumblers, if that is the problem.
I sprayed white lithium grease on the key and it works great, at least for now.
| All times are GMT -8. The time now is 08:34 AM. |
