Key bites, would not turn to start
The key goes in but would not turn to start the engine. Is it the locking mechanism? Can it be fixed or I need a new one with a key?
1984 944 N/A Passadena Gold, No Sunroof
1971 Cuda 440-6, 4 Speed, The Last 440-6 Cuda built, Black
1971 Cuda 340, A/T, Rallye Red
1970 Cuda Ragtop, 383, 4 Speed, Triple Black
Old 05-04-2022, 03:57 PM
Have 944, will restore
mazdaverx7's Avatar
Sometimes I have similar issues with my car as the key is worn. Just playing with it seems to do the trick. Does your key work fine in the door, hatch, and glovebox?
Also ensure that you're steering wheel is not locked. A you know, a locked steering wheel will prevent the ignition lock cylinder from turning.
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 05-05-2022, 03:34 AM
The key works OK with door and hutch locks. I had issues for the past few years, I would play with it and it would turn. Yesterday it would not, luckily I was home. I thought of spraying white lithium grease on the key and it worked at least for now. I would buy a new one but I am not eager to spend $250.00 plus for it. Anew key may help, mine seems worn, Porsche should make keys to last more than 38 years !!!
Old 05-05-2022, 06:39 AM
Your ignition lock is worn out. If the key work in the door and hatch, the key is good.
The lock needs to be replaced.
Good luck, George Beuselinck
Old 05-05-2022, 06:59 AM
Old 05-05-2022, 07:07 AM
A locksmith might be able to replace the worn tumblers, if that is the problem.
Early '85
Old 05-05-2022, 07:29 AM
I sprayed white lithium grease on the key and it works great, at least for now.
Old 05-07-2022, 05:48 AM
