mhariush's Avatar
Steering column play / loose 1978 924
The steering column is "loose" and has some play in it, anyone know what could be the cause of this?
https://youtu.be/4v5EiM7KiXw
https://youtu.be/bCtKCIhdu_o
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 04-06-2023, 09:27 PM
My 83 had a worn plastic column bushing that was the cause
Old 04-09-2023, 07:41 PM
mhariush's Avatar
I was reading up on some other threads and found the missing piece, the black plastic sleeve, when I pulled that off I was able to see that the inner plastic support ring had disitegrated. Looks like they used the same plastic as the odometer gears...
Old 04-09-2023, 08:51 PM
Part 171 419 341?
Good luck, George Beuselinck
Old 04-11-2023, 10:45 AM
mhariush's Avatar
Originally Posted by 944 Ecology View Post
Part 171 419 341?
yeah, that's the one. Also replacing the plastic sleeve and the bearing while it have it out.
Old 04-11-2023, 12:17 PM
