944turrboo's Avatar
Speedometer Not Working!
Hey does anyone know if the speedometer and the trip meter is controlled by the same speedo cable? My trip odometer is still counting but the speedometer isnt moving.. i cant tell how fast im going.. please help!
When life passes you by.. DOWN SHIFT!
Old 06-08-2003, 03:22 AM
SoCal Driver's Avatar
85.5 and later 944's do not have a mechanical cable coming off of the left front wheel. Instead there is a sensor (pulse generator) on the transaxle (drivers side axle/differential cover plate). Most likely you have lost the amber colored drive gear that the electric stepper motor drives inside the speedo unit. This gear ages and just falls apart -- kind of like old 944 drivers!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-08-2003, 09:20 AM
944turrboo's Avatar
do i need to take my speedo out to replace it?
Old 06-08-2003, 07:43 PM
Bob's944's Avatar
Send a message via AIM to Bob's944
Quick fix for alot of VDO gauges is to slap the top fo the dash. My speedo and tach both work fine after the tap. Cost zero.
Old 06-08-2003, 07:50 PM
