Engine Associated Wiring Layout - References?
Something that's been bugging me lately...that during the process of re-assembling my engine after rebuilding it - I'd neglected to take good photographs of the exact routing of various wiring networks...nor did I note the sequence of wiring layout as an integral part of the reassembly process - resulting in my occasionally having to route wires in what are possibly less than optimal locations.
At any rate...does anyone here know if there exists any good references relating to physical, engine-associated wiring layout...which might also mention proper wire clamp sizes, types, and locations? Thanks! |
What areas exactly do you need. I have an 86 NA that is original factory.Never modified.
I've owned it since 87. I can snap a pix for you for reference. Let me know.
1986 944 NA 2009 Cayenne |
Google image searches of 944 engine bays is the only guidance I can offer.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP |
Finding the original wiring tie downs will be challenging. Maybe 944online has them.
