I need HELP guys!
Can someone look at their O2 sensor & tell me were the wire leads to under the hood? PLEASE! It's an early 85....Thanks a million!
Old 02-02-2001, 08:19 AM
Shaun
Your pic didnt show up -- the reason I need to know is that Im missing the wire that runs between the sensor itself & the wiring harness, and am going to have to splice in something myself -- does it connect to a wire that looks like an ABS connection? Thanks
Old 02-02-2001, 01:51 PM
lm6y's Avatar
Nope Shaun, it's a dead link.
Old 02-02-2001, 07:45 PM
wolfrpi's Avatar
Look on the fire wall next to the dme pick up connections (There should be two sets of male and female connectors coupled together in a metal brace near the rear of the cylinder head and above the flywheel). In close proximity is the O2 sensor hook up. I believe it is cylindrical in shape and black in color.
Erick
Old 02-02-2001, 10:06 PM
Hey thanks Shaun -- thats what I thought it was....just wanted to make sure....I called a local dealer & they said they cant order just that wire...anyway, so if anyone has one they want to sell???
Old 02-03-2001, 05:46 PM
Shaun
How do you post pics? I took one because there are 2 empty wires at that location. One is fat & green (1 wire) other has two smaller wires (one male & one female)....is the green wire for an ABS option maybe????
Old 02-06-2001, 09:53 AM
Which one is it??
Old 02-07-2001, 05:01 AM
http://albums.photopoint.com/j/View?u=1505934&a=11369557&p=40262028>
Lets try it again
Old 02-07-2001, 05:02 AM
Old 02-07-2001, 05:03 AM
Shaun,
Finally got it - which one is it ??
Old 02-07-2001, 05:05 AM
Location: Las Cruces, New Mexico, United States of America
Send a message via ICQ to Porsche 951 Fanatic
nm... I messed up
[This message has been edited by Porsche 951 Fanatic (edited 02-07-2001).]
Old 02-07-2001, 10:12 AM
Ah, there's a reason why you're not seeing that connector, Shaun. Early cars have a one-wire oxygen sensor, and late cars have a three-wire sensor. If you're looking for a three wire connector in an early car, you won't find one.
Old 02-07-2001, 04:25 PM
So its the GREEN wire then?
Old 02-07-2001, 05:50 PM
Hello??
Old 02-08-2001, 05:21 PM
lm6y's Avatar
Yes Weldin, it's the green wire. You will need the connector that plugs onto the one that is empty if you don't have one.
Old 02-08-2001, 06:21 PM
