-   -   Locking Gas Cap Question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1152238-locking-gas-cap-question.html)
Dano944 12-17-2023 09:15 AM
My ‘83 944 has a locking gas cap, in which the ignition key fits. The key turns the lock but nothing locks. I don’t see anything that would make the cap “lock”. The car is my weekend driver, so the non-locking cap isn’t an issue except I like things to be working. I assume I’d need to buy a new working gas cap (if available), but how does one get a new gas cap keyed to my ignition key?
wwdwgs 12-17-2023 09:57 AM
Clean and lubricate the lock.. Try your key again.
kdjones2000 12-17-2023 05:39 PM
The cylinder can be swapped into a new gas cap if needed.
Dano944 12-17-2023 06:23 PM
Thanks for the replies. Question: What makes the gas cap lock? I see no moving parts when the key is rotated.
wwdwgs 12-17-2023 07:15 PM
Internally? I guess, that the cap's "handle" doesn't get engaged with the rest of gap cap's body (threaded part) and spins freely.
originalowner 12-18-2023 08:23 AM
When you put the cap back on, you turn it until it clicks. Then the cap then spins freely in the removal direction. When you insert and turn the key, it stops the free spinning action and the cap can be removed. It is really an "unlocking gas cap."
dme 12-22-2023 06:29 PM
One of the first things I did when I got my car was to rekey the cap to my ignition key. I found a link from someone who had already done it. I remember it as being pretty easy. Unfortunately, I don't remember the procedure or the link, but I did take pictures.http://forums.pelicanparts.com/uploa...1703298502.jpg
Dano944 12-23-2023 08:29 AM
Originally Posted by dme (Post 12157135)
One of the first things I did when I got my car was to rekey the cap to my ignition key. I found a link from someone who had already done it. I remember it as being pretty easy. Unfortunately, I don't remember the procedure or the link, but I did take pictures.]
Thanks. Good photos. I soaked my gas cap in WD40 and waiting to see if it’s better.
Dano944 12-23-2023 05:13 PM
Well…WD40 only helped the gas cap to spin easily, but nothing “locks”. I don’t leave my car anywhere to get gas siphoned, so I’ll just leave it. I’m happy with a cap that tightens and doesn’t leak.
djnolan 12-24-2023 04:43 AM
try wd40 in the key slot, and work the key a few times, one of the tumbler may be stuck. You may need to disassemble the cylinder and clean out corrosion. Had a similar problem with the hatch lock cylinder once.
dme 12-24-2023 08:29 AM
There is a video on youtube to disassemble the cap.
