Locking Gas Cap Question
My ‘83 944 has a locking gas cap, in which the ignition key fits. The key turns the lock but nothing locks. I don’t see anything that would make the cap “lock”. The car is my weekend driver, so the non-locking cap isn’t an issue except I like things to be working. I assume I’d need to buy a new working gas cap (if available), but how does one get a new gas cap keyed to my ignition key?
Old 12-17-2023, 09:15 AM
Clean and lubricate the lock.. Try your key again.
Old 12-17-2023, 09:57 AM
In the Fires of Hell.....
kdjones2000's Avatar
The cylinder can be swapped into a new gas cap if needed.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 12-17-2023, 05:39 PM
Thanks for the replies. Question: What makes the gas cap lock? I see no moving parts when the key is rotated.
Old 12-17-2023, 06:23 PM
Internally? I guess, that the cap's "handle" doesn't get engaged with the rest of gap cap's body (threaded part) and spins freely.
Old 12-17-2023, 07:15 PM
When you put the cap back on, you turn it until it clicks. Then the cap then spins freely in the removal direction. When you insert and turn the key, it stops the free spinning action and the cap can be removed. It is really an "unlocking gas cap."
Early '85
Old 12-18-2023, 08:23 AM
dme dme is offline
One of the first things I did when I got my car was to rekey the cap to my ignition key. I found a link from someone who had already done it. I remember it as being pretty easy. Unfortunately, I don't remember the procedure or the link, but I did take pictures.
Dan
86 Guards Red 951 (the best so far)
86 Black 951 (sold 12/31/09 PITA)
86 Guards Red 951 (sold in 7/15/00 (first love)
90 Plymouth Voyager, 2.5 Turbo 5 speed
Old 12-22-2023, 06:29 PM
Originally Posted by dme View Post
One of the first things I did when I got my car was to rekey the cap to my ignition key. I found a link from someone who had already done it. I remember it as being pretty easy. Unfortunately, I don't remember the procedure or the link, but I did take pictures.]
Thanks. Good photos. I soaked my gas cap in WD40 and waiting to see if it’s better.
Old 12-23-2023, 08:29 AM
Well…WD40 only helped the gas cap to spin easily, but nothing “locks”. I don’t leave my car anywhere to get gas siphoned, so I’ll just leave it. I’m happy with a cap that tightens and doesn’t leak.
Old 12-23-2023, 05:13 PM
try wd40 in the key slot, and work the key a few times, one of the tumbler may be stuck. You may need to disassemble the cylinder and clean out corrosion. Had a similar problem with the hatch lock cylinder once.
Old 12-24-2023, 04:43 AM
dme dme is offline
There is a video on youtube to disassemble the cap.
Dan
Old 12-24-2023, 08:29 AM
