best way to change clutch
im sure someone out there has done a clutch change on a 944. is there a good tip that anyone out there can give on how to replace the clutch. hey Ahmet, i know you must have changed at least 50 clutches . btw, i still have that 83 944 chassis. its almost ready to go to a good home to whoever wants it.
Old 02-10-2001, 10:23 PM
wolfrpi's Avatar
944 faq
Old 02-11-2001, 12:44 AM
No, Ahmet has changed at least 50 transaxles, not clutches
Old 02-11-2001, 10:20 AM
1.2gees's Avatar
Send a message via AIM to 1.2gees
I actually changed the clutch to a sport/lighter unit from centerforce soon after buying my car. When the transaxle was taken out of the car (because of burnt pinion bearings), I decided to go ahead and proceed with a clutch change while I was there.
If you're doing this yourself, make sure you realize your transaxle is going to be off the car, along with the exaust, and the torque tube will be loosened, moved a little bit. I'd recommend at least a haynes manual. Excellence also had an article about changing clutches on 944s not too long ago. Factory manual is superb as well.
Anyway, watch out when you're unbolting the bolts that go through the torque tube, to the block. Could try something like liquid wrench, or WD-40 (or something similar). Also make sure the clutch is aligned, while putting it in.
NOTE: When the clutch was pulled at 90+k, the rubber centeral dampener had a lot of cracks on it, but the wear was barely past halfway of the friction meterial.
Good luck,
Ahmet
It's all the driver...
[This message has been edited by 1.2gees (edited 02-11-2001).]
Old 02-11-2001, 07:08 PM
