Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Question brake pad ?
Soon I will buy some parts to pelican
I need brake pads but I saw that are expensive ! but exist diferent brands and prices.
I don`t use the car on track , autocrossing and is not a daily driven car
what are your opinion about this:
Mintex Front Brake Pads, 924/924 Turbo (1979-82, W/ M471), 944 (1983-88), 944S (1987-88), 924S (1987-88)
E-351-951-02M $33.95
Mintex Rear Brake Pads, 924/924 Turbo (1979-82, W/ M471), 944 (1983-88), 944S (1987-88), 924S (1987-88)
E-352-951-02M $33.95
Old 06-17-2003, 08:13 PM
Scott R's Avatar
I just installed Mintex pads from Pelican this weekend, it made a HUGE difference in stopping power. Get the Mintex!
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-17-2003, 08:15 PM
Scott:
Always id good to ear about you.
thanks for the tip,
best wishes
Old 06-17-2003, 08:32 PM
adrian jaye's Avatar
dont forget that non-OE brake pads are not always the same as the OE parts.
I know a person who bought some pads (which were a lot cheaper) and had loads of problems wityh brake squeel, only to find that the new pads did not have the bonded on anti-squeel shims.
just beware, cheap is not always best and all OE /OPC parts come g'teed and are correct for your model.
IMHO
HTH
A
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 06-18-2003, 01:09 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
I just cooked a new set of Mintex on the track this past weekend. They are not good for track!!! I got what I paid for....cheap brakes! I got too aggressive I guess...Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 06-18-2003, 04:02 AM
Scott R's Avatar
Mine are holding up great. BTW you can and will have brake squeel on any incorrectly installed brake pads. I have always had been able to get rid of squeel reguardless of the pad compound.
Always lube and clean all contact points, score the rotors and the pads of necessary, and install any missing damper shims or plates.
My setup does not squeel at all, no matter the type of pads.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-18-2003, 05:51 AM
AFJuvat's Avatar
I like Pagid myself
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-18-2003, 11:10 AM
Jean-Marc's Avatar
I have also used a set of Mintex on my 951 (use on track), and I found them just slightly better than the original in terms of power and wear.
I used blue Pagids before and they were far better (power) but wore much faster.
Jim
Club944.net
Old 06-19-2003, 11:55 PM
Scott R,
How do you score the rotors/pads?
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 06-20-2003, 04:51 AM
Eduardo-I chatted to you in an earlier thread about possible use of Volkswagen pads so I take it they were either not suitable or Mintex was not that much more expensive.I would guess the E-351-951-02M front and E-352-951-02M code would be an international description.Is Mintex supplied by specialist part dealers or widely available?
Old 06-20-2003, 06:50 AM
Paul:
hi,
Like you, I always have problems to find parts (in my country)for my Porsche cars, that was the main reason to try to find replacement parts.
I do not research about a replacement for the 944 brake pads yet, in this moment I need to buy several parts and I found that pelican gave a great support and assistance with my International orders (Tom Gould).
Then I will take this oportunity to buy the pads for the 944.
I supose that mintex is and aftermarket brand.
I'm 100% secure that if I take out 1 pad and I will go to a brakes store I will find a replacement.
But a lot of aftermarkets brands will have pads for the 944
I don't know if exist vw pads that will work like a replacement for the 944, maybe or maybe bmw, mercedes.
I only told you that I found in the vw rabbit pads a replacement for my 911 m calipers.
Search, I'm sure that you will found a replacement
good luck and regards
Old 06-20-2003, 11:03 AM
924Sman's Avatar
Try www.raceshopper.com Sman
Old 06-20-2003, 11:17 AM
