least common denominator
scottmandue's Avatar
Porsche Crest Hey all you mechanics, fantasy maximum 944 N/A engine!
Let's start with: THIS IS COMPLETELY THEORETICAL, so don't tell me to go out and buy a turbo.
Just as an engineering challenge/project.
Working with a 1984 2.5L block and no forced induction - can be driven on the street (Calif. emissions)
I will start with (is this even possible?) a 3.0 crank to stroke it to 2.7
High compression pistons (10:1?) how high can you go on street gas?
Intake and electronics off a 1986 or later 944 (plus Wilks chip).
Bored throttle body.
MSD ignition.
Can it be done?
what would you add or take away from that list?
Comments? condemnation? confusion? conundrums?
TIA
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 06-26-2003, 11:04 AM
the 3.0 crank will cost over a grand then you need to get the block machined but, yes it has been done
11:5 custom pistons are possible and with the 3.0 crank you'll probably need the custom pistons since the wrist pin locations on the 3.0 are different
Tom
Early '85 944
Old 06-26-2003, 11:12 AM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
88 na's are 10.2:1 and i would stick to somewhere around 11:1
-for California 91 anyway.
besides ive been told (don't know if its true) that doing anything to your engine in CA even if it dosent pollute more can fail the somg test. Like a K&N on an obd2 car.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 06-26-2003, 12:01 PM
Kirby2's Avatar
Web Cam will give you a mild street grind cam for $450 (10-12 hp).
Mass air conversion available for $700 (10-12 hp).
Hi Flow Cat replacement $250 (unknown HP, but much better sound).
Custom Chip $300 (again 10-12 HP).
Adjustible Fuel Pressure meter and guage. (5-6 hp).
Head port & polish $3-400 (5-6 hp).
Don't know if these items would be additive in their HP (Use the formula.... more air + more fuel = more HP).
03 Silver PT Turbo - Ours
86 White 951 - His
86 White 944 Manual - Hers
98 C-4 Sons
86 Gold 944 Auto - Sons
84 Maroon 944 Auto - salvaged
78 Yellow 924 - found a new home
Old 06-26-2003, 12:29 PM
fast924S's Avatar
Send a message via AIM to fast924S
Im not sure about running a 11.1 compression ration on street gas, You may run into some problems. As far as the 2.7 do it. Then get the head work done, cam, mass air flow, chip and I think huntley racing has a larger intake and exhaust valve conversion for the 944/924 head. The biggest problem with the 2.5 liter engine is lack of air flow. SO like kirby said More air+more fule= more HP. So whatever you do make sure that 2.7 liter can take in all the air and fuel it needs and you will notice a huge difference in power. Also I would get the engine balanced and any parts that you can lightened, also get a good clutch and if you really wanna get crazy get a lighter flywheel. That engine would kick some ass if you did all this. Good luck
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 06-26-2003, 02:01 PM
Scott, if you read the reply about your idea on the crank thread, I like highboost's idea about increasing displacement by increasing the bore. That should make it a more rev-happy design than stroking the 2.5 (makes more $ sense if you need custom pistons with the 3.0 crank). I would also think that increasing the displacement and the compression (watch your emissions here) would make the benefits of a better cam grind more pronounced. Might make enough extra hp to approach being worth that $450.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 06-26-2003, 02:05 PM
Kirby2's Avatar
California has new NO2 standards that KILL high compression dead! It's only a matter of time for other states. With NO2 there is no easy fix: too lean = more NO2, too rich = higher CO. NO2 can't be tuned out with better ignition.
86 White 951 - His
98 C-4 Sons
Old 06-26-2003, 02:12 PM
does that mean 20 year old cars need to rebuild to meet the new standards ? ?
Tom
Early '85 944
Old 06-26-2003, 03:29 PM
This is all pie in the sky dreamy talk...
But IIRC Excellence did an article where someone dropped a S2 into a early 944, maybe more cost effective to find a rolled S2.
Or buy a good condition S2 in the first place!
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 06-26-2003, 04:03 PM
rbt944's Avatar
Get some custom titanium connecting rods, shave the cylinder head to raise compression that way you wont' have to make the piston's heavier. Get some stronger valve springs. knife edge that crank. Port and polish.
If you were to build that motor it would be nice. But the California smog patrol will kill you.
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 06-26-2003, 09:15 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Lets say we raise compression to the 10.2:1 using euro pistons, then we knife edge the crank, decent cam.
Lindsey has a P/P that raises head flow by almost 40%... Use this with a new intake manifold, MAF
This is my plan... it'll probably only take a few years lol
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 06-26-2003, 09:35 PM
Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
I'm agree with scottmandue
yesterday solds on ebay a complete s2 engine with motronic and harness at 1300 usd.
You easily will spend a lot more and you never will have the hp and torque of this engine
My engine is ok, but I'm thinking in this upgrade, my car is auto, I will need torque!!!!!!
Old 06-26-2003, 09:37 PM
vott does ziss do?
ronin's Avatar
that makes me wonder if an 'S' 16v head conversion would be possible
Old 06-26-2003, 09:52 PM
My 85.5 is running almost 11.0 to 1 compression and I would not go any higher for the street. The cheapest way to go would be to get a set of 88 pistons and then have the head milled. Depending on the cam you use you can get the compression up to between 10.5 to 11 to 1.
Old 06-27-2003, 09:51 AM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
yOU ASKED FOR THIS.. gO OUT AND BUY A tURBO!
Ha!!!
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 06-27-2003, 11:00 AM
944pete's Avatar
Anderson Motorworks builds a nice 3.1L N/A engine.
Pete
1989 944S2-Dove Blue Metallic
1985.5 944-Alpine White--sold
My P-car Online Profile
Old 06-27-2003, 12:04 PM
justin's Avatar
Hey I have an idea!! Everybody send me the money to do this and I will build a bad a$$ engine how ever y'all want and put it in my car..... lol
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 06-28-2003, 08:58 PM
rbt944's Avatar
Justin, you should just swap in the 928 engine in your 944 and your 944 engine in your 928.
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 06-29-2003, 12:18 AM
Obin Robinson's Avatar
more info please
"Resale value": the phrase most often uttered by people who are afraid to admit they can't afford their car.
Old 06-29-2003, 02:47 PM
stupenal's Avatar
do any aftermarket tuners offer a lightweight flywheel? under drive pullies? possible to change to a different differential? it seems as if there aren't that many bolt on options for the 944 compared to other cars.
1997 M3 Sedan 5spd Artic Silver/Dove
M3 Bumpers/Mirrors/Sideskirts
S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes
Oh wait...it's a stock M3
Old 06-29-2003, 10:38 PM
