-   -   Engine loads up and backfires (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/116520-engine-loads-up-backfires.html)
Kirby2 06-26-2003 01:24 PM
This drives me crazy: If I run a fuel system cleaner like techroline through I get about a tank of gas before the engine starts to load up again. Tune Up and gas line cleaner are only temporary fix for this problem.
I'm thinking throttle position switch or the screwball air flow meter.
Help!
SoCal Driver 06-26-2003 01:44 PM
Does the techroline contact the TPS or the AFS?
Try fuel pressure regulator and fuel dampener.
Also the fuel filter.
Then start checking for vacuum leaks and bad engine to chassis grounds.
