Kirby2's Avatar
Engine loads up and backfires
This drives me crazy: If I run a fuel system cleaner like techroline through I get about a tank of gas before the engine starts to load up again. Tune Up and gas line cleaner are only temporary fix for this problem.
I'm thinking throttle position switch or the screwball air flow meter.
Help!
Old 06-26-2003, 01:24 PM
SoCal Driver's Avatar
Does the techroline contact the TPS or the AFS?
Try fuel pressure regulator and fuel dampener.
Also the fuel filter.
Then start checking for vacuum leaks and bad engine to chassis grounds.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-26-2003, 01:44 PM
