where to get new seal for front turn signal
It's nice that there are many sources for the front turn signal lens kit, but is the gasket available separately? I've looked at the usual places and don't see it for sale for the turbo/S2 style lens.
1984 944 Zermatt Silver
1987 951 Flamingo Metallic
Old 04-14-2025, 05:21 AM
In the Fires of Hell.....
kdjones2000's Avatar
Only944 has them
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 04-15-2025, 09:24 AM
Originally Posted by kdjones2000 View Post
Only944 has them
under 'marker light seals '
note: Made of soft foam rubber and it’s very easy to install.
I assume the OEM ones were rubber, and this appears to be foam rubber ?
I just bought a roll of 8 guage wire, not from this supplier, it was amazon, but I got it , wow it doesnt; feel very heavy I noted,,
and THEN I noted it says "copper coated alunimum wire". wow you have to pay attention these days. I didn't see that in the amazon ad I guess I jumped to the wild conclusion that 8 guage wire would be copper.
I cant see any practical use for ithis roll of garbage.
if its basically a flat seal I do have a source fdor flat rubber in sheets, maybe one can be cut out from that?
Old 04-16-2025, 11:52 AM
