Under any electrical load car looses power. More so than normal. Something as simple as running the car with Park/Fog lights decreases HP by about 10. At night. Running headlights and maybe the radio, fan kicks on and lights brighten and dim until fan stops. The car just about stalls. I cleaned all grounds, cleaned up the terminals. The belts are tight. I would hate to spend $200 on an item not needed. New to boards Thanks Sabyre |
The alternator has a voltage regulator attached.
Remove it and match it up to a new one at the parts store. Cheap money usually $20. If it helps great. if not well, nothing ventured nothing gained. Rick
'83 944 "Guards Red" New Everything (seems like) 16" 968 Wheels has never left garage (yet) |
10,000 watt stereo systems have a tendency to stall most any car.
Clean the grounds from the engine to the chassis too.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Have you read the Haynes manual check up.You should have close to 12v at battery engine not running, and 14 to 15V running otherwise brushes or regulator probably going or gone. Have just had mine replaced yesterday and had the comutator skimmed by the auto electrician as it had worn oval and one brush hardly existant. Save some bucks if you take the alternator out yourself then have auto electrician skim comm and test.
