adrian jaye's Avatar
noises
ok, just a continuation of various noises,
ok, herse some gen.
1) clucth changed a year ago think for a spring rather than rubber one
2) belts def loose
3) noise rattle from front also a bit tappety as well
4) last oil change I used 10-40 Shell helix plus
5) the infamous 5th idler wheel noise
I filled the transaxel with molyslip and threw some hydralic valve lifter lubrucant, also thinking of changing oil for 15-50 mobile one
anyone used swepco for transaxel and cured or at least made better the noise ?
another though we (me and makis) had, was that the rattle noise from the front, "seems" to be similar to the noise from the rear, again this noise is also more prevalent when engine/transaxel has warmed up.
we think is being transmitted through the clutch (which prbabaly is of spring design) from the noisy idler gear at the back, sounds similar
ideas ?
cheers
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 07-13-2003, 03:45 AM
