ilikemy944's Avatar
Send a message via AIM to ilikemy944
Low compression numbers due to valve, why?
Looking at a turbo, maybe.
Lower compression in one cyl. due to an intake valve... what would cause this, would it need immediate replacement?
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 07-14-2003, 03:01 PM
SoCal Driver's Avatar
What test was done to clearly indicate an intake valve as a problem?
Could be a scored cylinder/bad rings.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-14-2003, 03:12 PM
Roger Hall's Avatar
Burnt, cracked, or bent valve could cause compression to leak. I am not sure about the 944 valve train but a broken, collasped, or cracked valve spring could also cause this problem. Alot of carbon build up can also prevent a valve from sealing properly.
SoCal has a good point though it could be the cylinder/rings. I would also suggest a bad head gasket. Head gaskets seem to be a common problem on these cars.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 07-14-2003, 05:07 PM
ilikemy944's Avatar
It was a PPI so I'd assume the results were from a leakdown...
What exactly is a burnt valve? The car still runs fine, so I doubt it to be a bent valve... And wouldn't a bad spring cause real problems at high revs?
Brad Tompkins
Old 07-14-2003, 05:14 PM
Roger Hall's Avatar
I have never had either problem so I am not sure, but here is my understanding.
A burnt valve is caused when the valve becomes too hot, and the heat causes the valve to deform.
Bad springs should affect an engine at any RPM.
Roger Hall
81 924 N/A
Old 07-14-2003, 05:29 PM
Only the exhaust gets "burnt". This is where there is a small bypass at the valve (cracked valve seat or a bit of debris like a lost washer) and the exhaust gases scours a bit of the seat and/or valve. this grows till there is almost no compression on the cylinder.
A leak down will tell you real quick if it's the valves or the rings/cylinder wall.
Having an intake leak is very rare unless there is something stuck in the seat. Then there could be a bit of burning but most likely predetonation of the intake gasses resulting in some serious damage.
Old 07-14-2003, 06:33 PM
