Talking 87 944s idle problem
Hello,
Im a first timer. I have an idle problem with my 87 944s. 86k. Recently had cylinder head rebuilt and all 16 valves new. It has had the problem since I bought it 2 years ago. When I pull up to a stop light the idle drops and sometimes the engine stalls. If it doesnt stall it will quickly recover and idle normally. I have already installed a new idle air reg. under the intake manifold, but that didn't fix it, although it seemed to improve for a month. I know theres a Porsche tech out there with the answer. I read a post somewhere that it was normal and a chip would fix it. What do you guys think?
Old 07-19-2003, 09:56 PM
TCMdocs944's Avatar
Welcome.
Put some info about your car in your signature line so we can help out a bit better.
First check in my opinion, given the age of the car is ALL vacuum lines. Check for connection and brittle or broken lines. Check the alien(air intake) hose. If that fails check the electrical connections to the different dme components.
Basically, your DME(brain) is reading the wrong signals.
Mark
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 07-19-2003, 10:01 PM
I have checked for vacuum leaks with choke cleaner and I checked the air intake hose from the Mass air flow to the throttle body but couldnt find any leaks. I'll check all the sensor conn. Thanks
1987 944s 86k never too old to enjoy the performance of a fine auto
Old 07-19-2003, 10:06 PM
TCMdocs944's Avatar
If that fails there are several vac lines under the intake manifold that are subject to heat deterioration.
Another obvious is grounds. If you have no other electrical symptoms this is probably a blind alley.
Good luck
Old 07-19-2003, 10:10 PM
and check Clark's (http://www.clarks-garage.com)
Idle adj at:
http://www.clarks-garage.com/shop-manual/fuel-08.htm
TPS test at:
http://www.clarks-garage.com/shop-manual/fuel-06.htm
and FRWilk's (http://www.frwilk.com)
AFM test at:
http://www.frwilk.com/944dme/afm.htm
Tom
Early '85 944
Old 07-20-2003, 08:47 AM
MrPants's Avatar
isnt this what FR WILK's shudder fix chip is designed to fix?
84 944 Non Alcoholic
Old 07-20-2003, 01:32 PM
good point...the DME 'learns' the 'conditions' and adjust to them...and must have the battery disconnected and then reconnected to re-learn...which takes about 10 minutes?? so to adjust to the new part it's best to 'reboot' via a 'power cycle'
Tom
Early '85 944
Old 07-20-2003, 02:37 PM
Hello I have had the battery out since replacing the reg. but I have also been driving the car for about 4 months since replacing the reg.
I know that on some GM cars there is a min. air rate adjustment that allows enough air to by pass the air reg (when fully closed) to maintain a min idle speed of around 500 rpm or so. I havnt been able to find any such adjustment on my Porsche, Does anyone know about this?
Old 07-20-2003, 02:48 PM
in response to "Scott, Can you tell me where the idle adjustment screw on the S is located" (from another website)
Originally posted by Scott Anderson
It is right under the throttle cam, on the throttle body, at the very back of the intake manifold.
Tom
Early '85 944
Old 07-20-2003, 03:19 PM
Thanks, so it sounds like I would adjust the throttle plate open to set a min air rate and then reset the Throttle position so it reads closed at the new setting. Is that correct?
Old 07-20-2003, 04:30 PM
Originally posted by londel
Is that correct?
I can't say…never did that one
ask SoCal and if he tells you to jump off a bridge...don't even appear to hesitate
hey Juvay is back…now where is Todwic ??
(I hope one of those jack stands he’s so fond of didn’t slip ! )
Tom
Early '85 944
Old 07-20-2003, 07:26 PM
