time for a new headlamp motor relay?
I've cleaned off my headlamp motor relay multiple times with alcohol and swabs but it seems like it'll work for a while, then the "up and down" and the "headlights staying partially up when the switch is off" keep coming back. Anyone have any ideas as to what else I can use/do to make this problem go away for good? Also, the relay was VERY warm (almost hot) to touch when I pulled it this last time even though the car/lights had been off for a whole day. Any ideas?
Thanks,
Matt
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 07-19-2003, 04:38 PM
SoCal Driver's Avatar
Replace the relay.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-19-2003, 04:49 PM
Have had similar problem. Bent the male relay earth pin in slightly to make better contact with female plug and walla it has given no more problems.
Old 07-20-2003, 11:56 PM
