Damn PO. This appears to be an audi? Fuel injector in my rail. The size is the same, connections the same, length the same..only difference is no hat at the end. Should I put it back in or get a genuine replacement? (think about it as if your spending your own money )
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Think everything is ok if I just put a new hat on it?
Compare the spark plugs. If things are different, you should see it. If they all look the same and the car runs fine, I wouldn't worry about it.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
The hats and seals come as a reseal kit at most parts stores including Pep Boys.
The ones I've seen and others have reported on do not have the conical recess/counter bore that the OEMs do. You can use a sharp large drill bit to fix the after market ones.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
P.S. You did check the intake to make sure the hat is not stuck in it?
how do you know that you are not driving an audi with everything switched except that fuel injector?
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
We are driving Audi's. Just ask a 911 owner.
Yeh, I checked for the hat but its a nogo. I have been pretty meticulous about this tear-down and haven't seen it. I examined it closer today and feel the spray may be 1/8-1/4 higher than the rest......Hmmmm doesn't sound that good. Hey Snap check to see if your car has 3 audi injectors and one porsche. I'll swap ya
Writer/Teacher
is that cyllinder's spark plug different from the others?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Yeh, so is the piston
Writer/Teacher
um. are you serious?
Just kidding about the piston.
Actually I seemed to have water infiltration into the number one and two. Odd FI was number two. The head gasket was in such bad shape I am not sure if I could really tell if it had anything to do with the injector or not.
