-   -   sensors? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/119917-sensors.html)
JH924S 07-21-2003 02:19 PM
sensors?
where does the round refrence sensor wire off the top of the bellhousing connect to? TIA
SoCal Driver 07-21-2003 04:39 PM
The third sensor?
It doesn't.
Scott R 07-21-2003 05:43 PM
Is it possible you're looking at the connector for the O2 sensor, its routed up to the bracket for the reference sensors?
JH924S 07-22-2003 01:16 PM
theres the two rectangular connectors on the wires to the two sensors on top then another wire below but the connector is circular with three prongs inside it. anyone bueller? thanks
Scott R 07-22-2003 01:28 PM
O2 sensor
1.2gees 07-22-2003 02:51 PM
That is the TDC sensor. (A "diagnostic" port for the dealer). So for you, it doesn't connect to anything.
Ahmet
JH924S 07-23-2003 05:27 AM
is it 02 or diagnostic. im thinking its 02 though also. thanks scott and ahmet for the help
Britwrench 07-23-2003 06:34 AM
It's the timing sensor for the dealer's engine tester. It has nothing to do with the 02 sensor.
Scott R 07-23-2003 07:50 AM
Do you mean the little plug attached to the lift bracket on the back of the head? Then yes thats a diag port, iot should have a little plastic cover over it. If its a wire coming up from the side of the bell housing then its the O2 sensor. I have seen several O2 plugs just hanging in funny places recently.
JH924S 07-23-2003 02:54 PM
yeh def was the diag. port thanks alot
