JH924S's Avatar
Send a message via AIM to JH924S
sensors?
where does the round refrence sensor wire off the top of the bellhousing connect to? TIA
1987 924S black on black , does it get any better?
Old 07-21-2003, 02:19 PM
SoCal Driver's Avatar
The third sensor?
It doesn't.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-21-2003, 04:39 PM
Scott R's Avatar
Is it possible you're looking at the connector for the O2 sensor, its routed up to the bracket for the reference sensors?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-21-2003, 05:43 PM
JH924S's Avatar
theres the two rectangular connectors on the wires to the two sensors on top then another wire below but the connector is circular with three prongs inside it. anyone bueller? thanks
Old 07-22-2003, 01:16 PM
Scott R's Avatar
O2 sensor
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-22-2003, 01:28 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
That is the TDC sensor. (A "diagnostic" port for the dealer). So for you, it doesn't connect to anything.
Ahmet
Cheers!
Old 07-22-2003, 02:51 PM
JH924S's Avatar
is it 02 or diagnostic. im thinking its 02 though also. thanks scott and ahmet for the help
Old 07-23-2003, 05:27 AM
It's the timing sensor for the dealer's engine tester. It has nothing to do with the 02 sensor.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-23-2003, 06:34 AM
Scott R's Avatar
Do you mean the little plug attached to the lift bracket on the back of the head? Then yes thats a diag port, iot should have a little plastic cover over it. If its a wire coming up from the side of the bell housing then its the O2 sensor. I have seen several O2 plugs just hanging in funny places recently.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-23-2003, 07:50 AM
JH924S's Avatar
yeh def was the diag. port thanks alot
Old 07-23-2003, 02:54 PM
