-   -   idle stabilizing valve - shorted b and c - idles perfect. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/121146-idle-stabilizing-valve-shorted-b-c-idles-perfect.html)
ae1969 07-29-2003 03:02 PM
To refresh your memory........ my cars idle was fluctuating up and down....and some times would go as low as to want to stall.
When I short b&c in the test plug it disables the idle valve and the idle stays ~900 rpm............. if I pull the short out the 700-1100 rpm bouncing returns!
Question:
1. Can the car be run with b&c shorted?
2. If disabled the idle valve and my idle is perfect. The assumption must be a faulty idle valve?.......... any other possibilities? I don't want to replace the valve to only find out the problem was else where?
Thanks!!
SoCal Driver 07-29-2003 04:06 PM
Which car is this?
ae1969 07-29-2003 06:49 PM
oh.... the 951.
Sorry. I have a new MAF and turbo and injectors and other goodies....
I was having cold start issues and now I am having this wandering idle that is cured with b and c shorted.
ronin 07-29-2003 07:12 PM
faulty idle valve?????? that's my guess.
oh wait, you said that ;)
AFJuvat 07-30-2003 03:03 PM
Sounds like a crapped up valve
Clean it out and try again before you replace Many times they can be salvaged
AFJuvat
ae1969 07-30-2003 03:41 PM
I'll try to clean it up.....
Is it just a mechanical valve? brake cleaner............blow it out.....and away I go?
1.2gees 07-30-2003 05:44 PM
It's mechanical, but cleaning is USUALLY a temporary solution, if at all.
Also, disabling the unit stabilizes idle, and that's cool but regardless of what's going on w/the idle stabilizer, idle should never get as low to the point of almost stalling.
Does this problem usually occur when the engine is cold, or all the time?
Ahmet
