ae1969's Avatar
Send a message via ICQ to ae1969
idle stabilizing valve - shorted b and c - idles perfect.
To refresh your memory........ my cars idle was fluctuating up and down....and some times would go as low as to want to stall.
When I short b&c in the test plug it disables the idle valve and the idle stays ~900 rpm............. if I pull the short out the 700-1100 rpm bouncing returns!
Question:
1. Can the car be run with b&c shorted?
2. If disabled the idle valve and my idle is perfect. The assumption must be a faulty idle valve?.......... any other possibilities? I don't want to replace the valve to only find out the problem was else where?
Thanks!!
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 07-29-2003, 02:02 PM
SoCal Driver's Avatar
Which car is this?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-29-2003, 03:06 PM
ae1969's Avatar
oh.... the 951.
Sorry. I have a new MAF and turbo and injectors and other goodies....
I was having cold start issues and now I am having this wandering idle that is cured with b and c shorted.
Old 07-29-2003, 05:49 PM
vott does ziss do?
ronin's Avatar
faulty idle valve?????? that's my guess.
Old 07-29-2003, 06:12 PM
vott does ziss do?
ronin's Avatar
oh wait, you said that
AFJuvat's Avatar
Sounds like a crapped up valve
Clean it out and try again before you replace Many times they can be salvaged
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-30-2003, 02:03 PM
ae1969's Avatar
I'll try to clean it up.....
Is it just a mechanical valve? brake cleaner............blow it out.....and away I go?
Old 07-30-2003, 02:41 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
It's mechanical, but cleaning is USUALLY a temporary solution, if at all.
Also, disabling the unit stabilizes idle, and that's cool but regardless of what's going on w/the idle stabilizer, idle should never get as low to the point of almost stalling.
Does this problem usually occur when the engine is cold, or all the time?
Ahmet
Cheers!
Old 07-30-2003, 04:44 PM
