Helicoil on Waterpump stud
Ok, so I got the broken WP stud drilled out. Tapped and helicoiled the hole, put the new stud in, and it works great.
One Question.... This stud is the one that portrudes into the water sleeve. How water tight is a helicoil? Is there something I should put on the threads/hole to make sure it doesn't leak? Thanks! |
Some sealant between the stud and the helicoil couldn't hurt Helicoils are not ewater tight
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Friend of Warren
Next time I would recommend using a Time Sert which is a solid threaded sleeve as opposed to the wound wire helicoil. http://www.timesert.com/
Kurt V No more Porsches, but a revolving number of motorcycles. |
