perfecto951's Avatar
Send a message via AIM to perfecto951
So i broke something else - but now it's serious.
So I finally got my clutch bleeder valve and I installed it and bled my clutch and brakes today. That went fine.
Then I decided to tighten up my sloppy shift linkage. I tightened the bolt at the transaxle and the shifter stiffened up a good bit - wonderful. However I decided to go further, I tried tightening the brace that holds the linkage....and the bolt snapped! The thread is stuck in the transmission housing and the bolt is still through the brace with the rubber bushings hanging on.
I’m so incredibly pissed off. I finally am ready to get my car back on the road after a few weeks and this stupid crap happens. I even bought motor mounts to put on! I don't know what to do - all I can think of is to drop the transmission and drill out the thread that broke off and get a new bolt to put through.
If anyone has any idea on what I can do PLEASE let me know. Someone suggested that I use "JB weld" however I don't trust it due to all the heat/tension that is put on the brace.
The picture shows where I think the bolt goes into.
1986 951, India Red. (Mine) - Not For Sale Anymore
1987 944, Alpine White. (Bother's)
2000 Audi A6 2.7 Biturbo Melange (Mom's)
Old 07-30-2003, 07:08 PM
Sorry to hear about that- If it were me I would drop the transaxle and drill and tap. I definitley wouldnt use JB weld. Im feeling your pain.
1987 944s 86k never too old to enjoy the performance of a fine auto
Old 07-30-2003, 07:58 PM
vott does ziss do?
ronin's Avatar
JB weld would be a temporary fix at best. londel is right, best way to deal with it is to drop the tranny.
Old 07-30-2003, 08:02 PM
seaboltman's Avatar
maybe try to find a way to take the screw out. maybe make a few cuts in the metal if you can get to it, and then take a screw driver and get it out? not really sure that sucks, sorry
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 07-30-2003, 08:06 PM
i'm just going to take that screwdriver and stab myself in the face with it instead.
so....how hard is it to drop the transmission
Old 07-30-2003, 09:31 PM
here is another diagram.
i'll figure something out. thanks for the support guys.
Old 07-30-2003, 09:38 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
That sucks... If ya need help (not that I can or anything, just like to offer it hehe), let me know.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 07-30-2003, 09:53 PM
i'm going to TRY the JB weld tomorrow just out of curiousity. but if it doesn't hold we get to learn how to take out a transmission.
i bought my mounts, so when i have some time maybe you and Richard can come assist me.
Old 07-30-2003, 10:01 PM
Bad luck
What is JB weld.I bought a door handle (expensive here) to replace a broken one, and it came out the vice whilest trying to drive mechanism pins out.It dropped & broke the tab off that holds handle to door (screwed from outer door). I think it is pewter so does JB weld hold?
Old 07-31-2003, 01:04 AM
AFJuvat's Avatar
Do not recommend JB weld for linkage bolt.
Go with the "cut a notch and try to unscrew the nut out" approach.
Paul. JB weld is an epoxy that supposedly has the strength of steel - it wirks well for applications that are not under stress or pressure (like shift linkage or door handles.
Drop me an email Paul, I may have a door handle for you
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-31-2003, 06:48 AM
so tuesday my transmission comes down. anyone know the dimensions of that linkage bolt. more importantly, does anyone know where i can get one?
Old 07-31-2003, 01:50 PM
anyone know if the 924 linkage support is the same as the 944's?
Old 08-01-2003, 11:56 AM
I would recommend contacting Jamie@944online.com or there site is www.944online.com
I just bought an engine wiring harness from them for my car. It was in great shape and they shipped it quickly. I also thought the price was very fair.
Old 08-01-2003, 12:45 PM
If notching the bolt and unscrewing it doesnt work you might try a reverse drill bit. Youll need a reversable variable speed drill so you can drill the bolt slowly in reverse. The idea is you drill in a little ways and then the drill bit catches and unscrews the bolt. It works pretty good sometimes but even if it doesnt catch and unscrew the bolt you have a hole in it and you can try an extractor. Tapping new threads is a last resort. Good luck.
Old 08-01-2003, 01:13 PM
