-   -   what else should i check while tranny is out? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/12152-what-else-should-i-check-while-tranny-out.html)
e_nough 04-09-2001 08:46 PM
hi,
i just pulled out the tranny for a rebuild. what esle should i check?
my mechanic says its a good idea to check the clutch, but that sounds like alot of work and it was replace about 30K ago with a spring-centered version.
how long does it take to check the clutch with a visual inspection. bear in mind that it took me about 6-8hrs to pull out the tranny, and im still learning and obviously very slow at this point.
