changing rocker cover gasket - xposted
hi all,
s2, got all the seals etc but a few questions 1> the torq screws what size are they ? 2> torq settings ? 3> there are 2 fuel pipes going across the cover, is there a trick to removing these, ie to minimise fuel loss, is it preassurised, do I need to stopper it ? 4> does the rocker cover gasket need to be sealed wet or dry ? cheers A
----------------------------------------------------------- The fear of God is the begining of wisdom <>< NotJustPorsche Subscribe: notjustporsche-subscribe@yahoogroups.com |
Hey Adrian,
1. Not sure - and FLAPS has a set of TORX bits - usually from T-10 - T-60 fairly inexpensively ($15 USD) 2. 25 NM 3. Depressurize be removing fuel pump fuse while engine is running - you can also loosen the nut on the end of the fuel rail to dump residual pressure 4. Dry AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
hey AF,
cheers ade
The gasket should have some sealer at each corner, look at the old one and you can see where the sealer should be.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
hey guy's,
Brit, yep I saw that, and did it. AF, the fuse thing was "booomin!" cheers my main problem was undoing the fuel pipe nuts, had to kinda bodge it, but it all turned out ok, sprayed the rocker cover guards red to match the bodywork. the timing chain seemed ok as did the camshafts
