my 1987 944na has 115K miles and got a new spring centered clutch at around 70K or 80K miles.
should I pull the torque tube and bell housing to check it. the tranny is out for a rebuild. how long does it take? do i need any special tools other than the cheesehead sockets? thanks |
i would check the clutch. you are halfway there if you were to replace the clutch. im not sure but is there an inspection hole on the bellhousing.
