I'm trying to replace my oil pan seal/rod bearings. I can't get the last bolt of the six between the exhaust manifold and the crossover pipe. It's of the middle ones set closest to the block. How the hell do you get a wrench/ratchet on the front and backside of this nut/bolt. Is an impact ratchet mandatory?
Last bolt of the 6 what? I'm not sure if I follow you there...
Just did this on my NA, actually got done yesterday, so I MAY be of some help. I didn't use anything but a 45 piece (?) metric tool set, with the addition of only a u-joint... Ahmet ------------------ It's all the driver... |
