AC not working
Yesterday I drove the car and the AC wasn't working - no drop in air temp at all. Prior to yesterday the system worked perfectly with really cold air (new compressor 2 years ago)
The lamp in the AC switch was on, and I could hear a change in the engine note when you pressed/released the switch.
Any ideas anyone?
Thanks,
Mark
1991 944 S2 (no more, sold it, gone to a good home)
2003 Infiniti G35 Coupe, 280hp, Black
Old 07-28-2003, 08:27 AM
Scott R's Avatar
Is your temp mixing system working? When you turn the temp knob does the air get hotter, then colder as it approaches outside temp?
If not your mixing flap clip may be broken.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-28-2003, 08:44 AM
Hmmm not sure, I'll try it tonight. Is it easy to fix?
Mark
Old 07-28-2003, 09:48 AM
Scott R's Avatar
10 min labor and about $3 for the parts. The clip is located just above and to the side of the gas pedal, behind a black plastic cover.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-28-2003, 09:58 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
what a coincidence. today i found out that my AC might actually work.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 07-28-2003, 10:24 AM
10 min labor? Isn't that a little generous?
Sam
Old 07-28-2003, 11:57 PM
OK so I tried the temperature control yesterday and it is working fine. Hot air when set hot and coolish air when set to cold. But no change when the AC button is pressed.
Any more ideas anyone? Thanks!
Mark
Old 08-02-2003, 07:43 AM
Also the radiator cooling fans are coming on - but no change in engine note when I pull the "AC Compressor" relay.
So it looks like either relay or the A/C electromagnetic clutch
Mark
Old 08-02-2003, 01:18 PM
Scott R's Avatar
Or your system is empty, jump the terminals on the pressure switch next to the dryer, see if that gets the compressor going.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-02-2003, 07:27 PM
Thanks I'll try that - but one day the system was working great, the next day nothing - it doesn't fit with a slow leak - maybe a sudden one.
I've got the compressor relay pulled to test it - will test it on monday.
Mark
Old 08-02-2003, 08:46 PM
Scott R's Avatar
When the compressor front seal went on mine it lost all of the pressure in a matter of moments.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-03-2003, 08:31 AM
TSNAPCRACKLEPOP's Avatar
yes, i saw the warp in the ozone layer that day.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 08-04-2003, 03:26 AM
Hoping its not the compressor, it had a new one from porsche 2 years ago at huge expense!
I suspect the relay or clutch.
Mark
Old 08-04-2003, 07:47 AM
Mine is doing the same thing and I can't figure it out. I just replaced the leaky hose, changed to R-134 (I think thats it), and it was working fine. THen yesterday it was blazing outside...and it won't work, and you can hear a relay clicking. I checked the relay and even tried to jump the relay today. CHeck connections at the compressor, and still nothing. I'm burnin up...
Yes the motor is in the front....
Old 08-06-2003, 12:05 PM
