Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Window rattling
When I closed my driver's side door with the window open yesterday, it made an irritating rattle. I stuck my finger down the window frame, and sure enough the window was loose and could move about 1/2 inch back and forth. When the window is up all the way there is no problem, and when it is partially up there is less rattling but it is still there.
Please tell me this is as easy as "take the panel off and tighten this bolt" !
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 08-12-2003, 07:37 AM
SoCal Driver's Avatar
Could be that easy. The rear track could be loose. Or just needs the felt window guides replaced. Or both.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-12-2003, 07:48 AM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
ok, I had the exact same problem, take the panel off and you should probabyl find the felt window holder in the bottom of the dorr, it has fallen off, and if you re glue it in the window rail it should be just fine.
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 08-12-2003, 02:15 PM
paulc's Avatar
try a pacifier instead.
87na guards red(mine)
98 suburban(mine)
04 4Runner(wife's)
Old 08-12-2003, 02:36 PM
