What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Up grades
Ok, Ive had it .. I am looking for the ultimate power upgrade. And I may need all the help I can gleen from this forum..Ive decided to drop an elephant into my car. Has anyone else done this? Is there anything I need to do to the suspension? How about fuel injectors and chips? Will I need new rims, tires?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 08-13-2003, 01:40 PM
Scott R's Avatar
Were you thinking about a 2.5L elephant, or a 3.0L? Does it run on peanuts? Can you add NOS to it at the same time?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-13-2003, 02:20 PM
Thanks for the e-mail's Gordon. I have a few things left from the 86 951 that will work on your 83. Front and rear sway bars, front springs, and a fuel pump. I have a throttle body, not sure if you can use it though.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 08-13-2003, 02:22 PM
ldl ldl is offline
ldl's Avatar
Elephant eh?
Meaning... a LARGE passanger?
Or quite possibly a LARGE engine? You thinking about doing one of those LT1 Swaps?
And for suspension, you're gonna have to add some heavier-duty springs in order to take the weight. And while on the topic of weight.... This swap will most likely destory the balance of this car. So before you do the swap or putting a large passenger in your car, make sure you spend some time and get all the information you can on this.
85.0 944 Automatic
^ Bending my wallet over at every possible moment.
Old 08-13-2003, 02:26 PM
TCMdocs944's Avatar
Simple answer,
Pigmy elephant from Borneo
Half the weight, twice the power..
Put the NOS in the trunk :-) of course.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 08-13-2003, 02:38 PM
Think I've found the ultimate upgrade :
http://www.autospeed.com.au/cms/article.html?&A=0764&P=1
This only has a small gas turbine - but I'm sure you could get a military jet engine in the back of a 944. The gearbox is already there anyway. Think of the kick you could get with the afterburner engaged - and imagine the look on that ricers face as you hurtle off with a fireball coming out of the back of the car.
This is the kind of effect you're looking for :
http://www.jetwebb.com/dragon.html
Mark
1991 944 S2 (no more, sold it, gone to a good home)
2003 Infiniti G35 Coupe, 280hp, Black
TCMdocs944's Avatar
________________________________________
Fuel mixture is a bit off, DME must be getting the wrong input. Maybe a bad chip upgrade?
Old 08-13-2003, 02:46 PM
