Question 924 turbo valve guides
1980 924 turbo....blows some smoke on start up and little when idleing....was told it the valve guides....how much work is involved to fix that? anyone had it done or done it themselves? cost?
Old 08-18-2003, 08:12 AM
Dave951M's Avatar
More likely the seals in the turbo. Could be both. I'm having my turbo rebuilt and am putting seal while the turbo's at the shop. Cost for turbo is about $350.
Dave951M
86 951 Blitzwagen
82 931 Basket Case (for now)
Old 08-18-2003, 08:22 AM
does it hurt the car to drive it like that?...cause i don't know when i will be able ot get it fixed
Old 08-18-2003, 08:28 AM
just in case you need some guides, I have 4 left overs from a rebuild. Like Dave said, could be the turbo. In my case it was both!
Old 08-18-2003, 09:21 AM
Dave951M's Avatar
It shouldn't if you keep your oil level up. Over time, it will clog the catalytic up and get progressively worse. If it's just seals, then it would probably be cheaper than what I'm spending. Bear in mind that I took out the turbo and carried it to a turbo shop. If I didn't the bill would be much, much higher.
Dave951M
86 951 Blitzwagen
Old 08-18-2003, 09:22 AM
I think the valve guide seals & plastic straw thing are less than $15. It is a lot of work though because valve springs have to come out.
drew1
Old 08-19-2003, 08:23 PM
