-   -   Interference engine (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/124092-interference-engine.html)
myfirst porsche 08-19-2003 09:05 PM
Interference engine
My 93 944 has stripped the teeth off the timing belt at the crankshaft pulley. Did i just bend some valves or is this even an issue? Hoping for the best.
very~worn~944 08-19-2003 09:09 PM
You have a 93 944!?! Damn! I want it...I will buy it off you for 30 kilobucks! And all this time I thought they stopped production...what size motor does it have? Ok..sorry for being mean..I had to do that...Assuming you mean 83? Does the car run? I would definately be scared if i were you...You could have 8 nice paperweights.
myfirst porsche 08-19-2003 09:13 PM
Sorry 83, no it does not run, It turns over very nicely but the camshaft does not move. I had a turbo daytona years ago and you could break timing belts all day long without a valve problem. I was praying that the porsche might be the same
gearhead290 08-19-2003 09:17 PM
the 944 is an interference engine...the daytona is not. Yes, i'm sure you have damaged something. If you need a head I have one...gearhead290@hotmail.com if interested
very~worn~944 08-19-2003 09:19 PM
No NO...your screwed...I am very sorry to be so blunt...but if your crank is spinning and your cam is not...you've got a nice juice squeaser...but thats about it. Those valves are 'bout as straight as Richard Simmons.
myfirst porsche 08-19-2003 09:20 PM
OK any one know of a good manual for these cars?
myfirst porsche 08-19-2003 09:23 PM
Since the car only has 50K on it i guess it is off with it's head, ha ha ha I crack my self up!!!! Thanks for the help
SoCal Driver 08-19-2003 09:53 PM
More likely 150,000 if not 250,000 as the odometer has 5 digits and not six.
And yes you have bent most if not all the valves.
What were you told about the timing belts on the 944?
The Haynes 944 manual will be a good start. See them all the time on eBay for $14.
If you are serious about keeping the car then the factory workshop manuals are worth getting. About $300 a set in paper or from free to $20 as PDF's on CDR.
ronin 08-20-2003 01:03 AM
for those that still don't know what an interference motor is. let me just put it this way. iffn ya dont keep after dem belts, sooner or later its really gonna interfere with yer cash flow :D
as mfp is about to find out
myfirst porsche 08-20-2003 08:49 AM
Thanks for the replies. Socal driver it is actually 50k. I have all the documentation on the car. Including the owner history and the milage each owner claimed when registering the car.
SoCal Driver 08-20-2003 12:48 PM
WOW!
What luck. Well maybe not as lucky as it would seem.
The timing and ballance shaft belts should have been replace at 30,000 miles or about four years as they deteriorate to where they loose teeth.
So what were you told about the timing belt when you bought the car?
P.S. With such low milage you can get away with just replacing the bent valves and lappin in the new ones as long as there is no significant damage to the valve guides.
P.P.S. Add your location and the year/model of you car to your info. Use the signiture line for the year and model.
myfirst porsche 08-20-2003 02:19 PM
Ok I have a manual and I read about dealers doing the cam belt tension. Any other way to do this? Tool available?
VINMAN 08-21-2003 06:51 AM
look on EBay for a factory manual on CD. there are pretty cheap
