Old 08-21-2003, 10:35 PM
bearone2's Avatar
High side pressures are well above the range of most tire gages.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 08-21-2003, 10:59 PM
vott does ziss do?
ronin's Avatar
whence ye hail, my friend? for I am endowed with said proper instrument, lest ye borrow that which is mine.
oh wait, you're in Cali, aren't ya.
vott does ziss do?
ronin's Avatar
so then why would you want to use a tire pressure gauge, *** ****?
Old 08-21-2003, 11:28 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
That Wilk, always a-thinkin. Y'know, a lot of bike gauges (where the shraeder has it's 3 most applied application, next to a/c and Big Apple Dominatrix') go well over 100psi (road bikes have insane pressures). How high would an auto a/c be? Do you have to check it on the high side? would the low side be adequate just to see if you have press. or not?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 08-22-2003, 12:06 AM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
how can you tell if youre system has been switched over to the new freon?
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 08-22-2003, 12:35 AM
When the system is off, the pressure should equilibrate to somewhere around 60 psig everywhere, depending on the temperature which defines the vapor pressure. I've never put my tire gauge on it but I don't seen any problem. My gauge is a Bourden (sp) type gauge. I even use it to check water pressure. Innards are brass, I believe. When running, high pressure side would be way to high for my gauge which only goes to 60 psig.
I'm off to Road Atlanta for a PCA DE this weekend. Leaving shortly and will enjoy my new Sanden compressor that I installed two months ago.
Also just finished replacing compressor on my old MB last weekend. I feel cool!
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-22-2003, 04:41 AM
BlueQuestTSi's Avatar
I can think of one issue with using a tire gauge(other than the high side pressure).
It would lead to frost bite You know how you always seem to lose about 5psi of pressure just trying to get the damn gauge to read on the tire..... Besides, most gauges are metal, it'll get cold real fast.
Here is a good question. Where can we get just the Barrier hoses without having to buy the whole Kuehl A/C kit?
Jack
86 Red 951 - Turbo Twists, otherwise stock for now
83 Black 944 w/86 951 front end - still down and out, but coming back slowly.
02 Altima SE 3.5 - grocery go-getter
00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi
Old 08-22-2003, 08:43 AM
bearone2's Avatar
I'm 57 years young and can't for the life of me ever remember any r12 cans with anything but the male threaded end which would be connected to the yellow hose on the a/c manifold set or directly to the low pressure, male threaded, side of the compressor.
If you piped it directly into the compressor from the can with the hose that came as a kit, without a manifold set, you had no idea what the high side pressure is, taking a big chance on running the pressure too high.
I've worked on a bunch of old a/c when r12 was $1 a can and never saw any r12 systems with a schraeder valve on the high or low side.
Old 08-23-2003, 10:04 PM
