clarifying my speedo problems
Some more info on my problem. The odometer doesn't work now, but the speedo needle bounces when you push the odo reset.
Wish I knew, my odometer only doesn't work, but bounces when you hit button.
-Dan |
SoCal addressed this one in some other threads.
Go to Clarks garage and follow his instructions for removing the Steering Wheel and Gauge Cluster. Sounds like a gear or maybe just unplugging the ribbon cable and plugging it back in....dont know cause I still havent gotten around to doing mine yet. :) |
I have removed the instrument cluster and cleaned the contacts. (for the other gauge problems). I guess I need to pull the part on the trans. and/or the speedo.
Ok-- Jumping needle, it's time for a new cable. Mine jumped for about the last 6 months until it finally just gave up the ghost- wrapping itself around the left side tierod making it impossible for me to turn..
That's Bad, MmmKay! I have had my speedo cable out a few times while solving the 2nd issue, no Odometer. Time for a new gear- Pull the speedo apart and check to see if the gear has self destructed- NEVER reset the trip meter when rolling!! I think KLA has the gears for the "new" dash.. If you are lucky (as I was) the gear just slipped off of the pinion- a dab of superglue and you are done! Good luck! |
I keep nickle and dimeing you guys with more info on the problem. here's more...the speedo didn't jump before. It quit working after I installed a new clutch. This weekend I'm gonna play some more with it. Hey Chris -924s... glad to hear your car has been so reliable. Mmmkay?
| All times are GMT -8. The time now is 09:53 PM. |
