clarifying my speedo problems
Some more info on my problem. The odometer doesn't work now, but the speedo needle bounces when you push the odo reset.
'87 944 Maraschino Red Metallic Euro delivery...five speed
Old 08-25-2003, 06:25 PM
uncwSoccer's Avatar
Wish I knew, my odometer only doesn't work, but bounces when you hit button.
-Dan
Old 08-26-2003, 07:35 AM
SoCal addressed this one in some other threads.
Go to Clarks garage and follow his instructions for removing the Steering Wheel and Gauge Cluster. Sounds like a gear or maybe just unplugging the ribbon cable and plugging it back in....dont know cause I still havent gotten around to doing mine yet.
1987 944 NA
Old 08-26-2003, 08:35 AM
I have removed the instrument cluster and cleaned the contacts. (for the other gauge problems). I guess I need to pull the part on the trans. and/or the speedo.
Old 08-26-2003, 06:59 PM
Chris_924s's Avatar
Ok-- Jumping needle, it's time for a new cable. Mine jumped for about the last 6 months until it finally just gave up the ghost- wrapping itself around the left side tierod making it impossible for me to turn..
That's Bad, MmmKay!
I have had my speedo cable out a few times while solving the 2nd issue, no Odometer.
Time for a new gear- Pull the speedo apart and check to see if the gear has self destructed- NEVER reset the trip meter when rolling!! I think KLA has the gears for the "new" dash..
If you are lucky (as I was) the gear just slipped off of the pinion- a dab of superglue and you are done!
Good luck!
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 08-27-2003, 06:08 AM
I keep nickle and dimeing you guys with more info on the problem. here's more...the speedo didn't jump before. It quit working after I installed a new clutch. This weekend I'm gonna play some more with it. Hey Chris -924s... glad to hear your car has been so reliable. Mmmkay?
Old 08-27-2003, 07:19 AM
