-   -   Heat shield part source? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/125091-heat-shield-part-source.html)
dugcat11 08-27-2003 06:59 PM
Hello,
My 944's rattling a bit and after inspection, I found a piece of metal (looks like some sort of heat shield) above the catalytic converter had broken off of its mounting bolt.
Looks like I need a replacement and I'm wondering if any of the usual parts houses offer it -- I've looked in the Performance catalog and here on the Pelican site and didn't find anything.
(Hoping I don't have to buy this thing from a Porsche dealer).
Kind Regards,
DL
Roger Hall 08-27-2003 08:26 PM
I checked the PET and I could not find a heat sheild listed. Sorry
Panzer909 08-27-2003 10:30 PM
Dugcat11-
Had the same thing happen to me over a year ago. Pulled off the rusty remains with the intention of replacing it, but never got around to it. I check everything around that area when I change the oil/work under the car and nothing is worn visibly. Regardless, not replacing a heat shield of any kind is a big NO NO, so call Partshaven. They'll hook you up.
adrian jaye 08-29-2003 08:08 AM
The heatsheild is NOT a separate item.
This is a common problem. you have several choices
1> fit a second hand cat
2> buy some heathshield material "SPECIOFICALLY" rated for a cat, and fit/wrap it around the cat
pls note the heatshield does NOT run the whole length of the cat, but about a 3rd of the way down from the front.
without this shield you may/will have the following problems
1> extra heat directed at the cabin area (around the console and hi-fi area)
2> if you park on an area with dry leaves after a fast run, you run the risk of igniting what you've parked over
HTH
Ade
dugcat11 09-07-2003 02:03 PM
"The heatsheild is NOT a separate item".
This statement caused a bit of uncertainty so I had another look today. On my early '84 (USA version), the heatshield (that item placed BETWEEN the chassis and the cat) is indeed a separate piece and is in no way physically attached to the converter.
With this in mind, I will continue my part search and provide an update on the result.
Kind Regards,
DL
Gordon Rankin 09-07-2003 05:58 PM
A good muffler shop can provide something close to stock or fabricate something for a nominal price,, "Been there, done that"
dugcat11 09-19-2003 06:44 AM
Part Source - Update
Just an update on my part search.
I found the part from a salvage operation in PA (they advertise in the PCA magazine - AutoTech is the name).
The salesperson there (Bill) was very helpful. He knew what I was describing and shipped it out to me.
The cost for the part (sans shipping) was $15.
I had of course called PartsHeaven but the salesperson there did not know what I was requesting and instead we ended up discussing a catalytic converter - PartHeaven priced at $175. FWIW the AuthTech price for the same part is $75.
Kind Regards,
DL
