Heat shield part source?
Hello,
My 944's rattling a bit and after inspection, I found a piece of metal (looks like some sort of heat shield) above the catalytic converter had broken off of its mounting bolt.
Looks like I need a replacement and I'm wondering if any of the usual parts houses offer it -- I've looked in the Performance catalog and here on the Pelican site and didn't find anything.
(Hoping I don't have to buy this thing from a Porsche dealer).
Kind Regards,
DL
84 944 5spd
Maint. & Fixes made thanks to the help received on this board:
Rear Hatch Pins, Oil Change, Dash Cover Installation, New Rear Seat, New O2 Sensor, New Ignition Switch, New Fuel Pump Relay, Rear Light Assembly Reseal, Instrument Panel Short Circuit, New Speedo Cable, New Timing belts and Starter.
Old 08-27-2003, 06:59 PM
Roger Hall's Avatar
I checked the PET and I could not find a heat sheild listed. Sorry
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 08-27-2003, 08:26 PM
Mein Gott!
Panzer909's Avatar
Dugcat11-
Had the same thing happen to me over a year ago. Pulled off the rusty remains with the intention of replacing it, but never got around to it. I check everything around that area when I change the oil/work under the car and nothing is worn visibly. Regardless, not replacing a heat shield of any kind is a big NO NO, so call Partshaven. They'll hook you up.
Old 08-27-2003, 10:30 PM
adrian jaye's Avatar
The heatsheild is NOT a separate item.
This is a common problem. you have several choices
1> fit a second hand cat
2> buy some heathshield material "SPECIOFICALLY" rated for a cat, and fit/wrap it around the cat
pls note the heatshield does NOT run the whole length of the cat, but about a 3rd of the way down from the front.
without this shield you may/will have the following problems
1> extra heat directed at the cabin area (around the console and hi-fi area)
2> if you park on an area with dry leaves after a fast run, you run the risk of igniting what you've parked over
HTH
Ade
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 08-29-2003, 08:08 AM
"The heatsheild is NOT a separate item".
This statement caused a bit of uncertainty so I had another look today. On my early '84 (USA version), the heatshield (that item placed BETWEEN the chassis and the cat) is indeed a separate piece and is in no way physically attached to the converter.
With this in mind, I will continue my part search and provide an update on the result.
Kind Regards,
DL
84 944 5spd
Old 09-07-2003, 02:03 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
A good muffler shop can provide something close to stock or fabricate something for a nominal price,, "Been there, done that"
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 09-07-2003, 05:58 PM
Part Source - Update
Just an update on my part search.
I found the part from a salvage operation in PA (they advertise in the PCA magazine - AutoTech is the name).
The salesperson there (Bill) was very helpful. He knew what I was describing and shipped it out to me.
The cost for the part (sans shipping) was $15.
I had of course called PartsHeaven but the salesperson there did not know what I was requesting and instead we ended up discussing a catalytic converter - PartHeaven priced at $175. FWIW the AuthTech price for the same part is $75.
Kind Regards,
DL
84 944 5spd
Old 09-19-2003, 06:44 AM
