-   -   removing ignition lock from cluster... HOW? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/12514-removing-ignition-lock-cluster-how.html)
Obin Robinson 05-09-2001 07:59 AM
ok, i need a bit of help here. i have to replace my ignition cluster (you know, that lightweight alloy thing around the steering column that the key goes into). i got a new one, but it doesn't have an ignition lock (the thing that the key goes into). how can i carefully remove my old one and plug it into the new one? i don't want to force it and bust it off.
thanks!
obin
A straight line is the most BORING distance between two points.
AMCPorsche924Powerhaus! 05-09-2001 02:36 PM
about 10 guys kep asking the same question over and over on 924.org
i explained it there a bunch of times over the past year.
drew1 05-09-2001 02:50 PM
Obin,
About 4 pages ago, Brandon85-944 had the same question. I put the dimonsions you use to locate & drill hole to get lock cylinder out. Powerhuas replied with where the allen screw is to get the collar off the steering column.
drew1
AMCPorsche924Powerhaus! 05-09-2001 04:11 PM
http://www.megaone.com/geoisfuct000/
pics are on that server
<IMG SRC=http://www.megaone.com/geoisfuct000/keyclip.JPG /A>
<IMG SRC=http://www.megaone.com/geoisfuct000/drill3.JPG /A>
<IMG SRC=http://www.megaone.com/geoisfuct000/drill1.JPG /A>
<IMG SRC=http://www.megaone.com/geoisfuct000/drill.JPG /A>
[This message has been edited by AMCPorsche924Powerhaus! (edited 05-09-2001).]
AMCPorsche924Powerhaus! 05-09-2001 04:39 PM
drill where the two top holes are, the other two that i drilled were just hit and miss, and I missed.
Right where the two top holes are with yellow arrow, the clip is, and you stick a pick in, and push on the clip as shown in keyclip.JPG, and yank the sucker right out.
Obin Robinson 05-09-2001 05:36 PM
wow, thanks guys, i was looking up the wrong keywords!
i am going to replace this one only because i am trying to get under the curtain for NY state safety inspection. after this is done, i am looking at wiring in a push-button starter. the centre console is coming out of my car, and i am measuring the place to put the centre guages.
thanks for the help though!
obin
