Send a message via AIM to Jason White
Question up grading early 944
can you up grade the early 944 suspension with the late alloy pieces? And I am looking for a roller 944 to rebuild anybody know of one?
JRW
1987 924S White
-daily driver w/86k miles almost stock-
1971 914 Red
-doesn't see road much-
Old 09-01-2003, 08:44 PM
adrian jaye's Avatar
dont think there is a problem with that !
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 09-02-2003, 01:17 AM
You can "upgrade" the front suspension, but you loose the mechanical speedometer drive from the left front wheel. To get around that you need to have a machine shop drill the spindle.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 09-02-2003, 06:24 AM
bertman's Avatar
Why would you want to do this "upgrade?"
bertman
84 944 Original Owner
65 Plymouth Satellite
08 Mercedes-Benz E 350 Sport
Old 09-02-2003, 06:35 AM
One thing I forgot: If you "upgrade" the front suspension, you loose the ability to chage the ball joints.
the early steel A arms use replaceable (VW/Audi) ball joints, while the later aluminum A arms do not.
However, you can rebuild the later ball joints. It's just a lot more work and about 3 times the expense of replacing early ball joints.
Cliff Hipsher
'87 944 India Red
Old 09-02-2003, 06:49 AM
I have all the parts sitting in my garage spindles, hubs, control arms, swingarms, brakes ect. And I heard the later A arms are stiffer and have a better offset or something. I may be wrong.
1987 924S White
1971 914 Red
Old 09-02-2003, 01:15 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
You will need wheels to do this "upgrade". I would just sell what you have. The late arms are indeed stiffer, and the parts end up reducing unsprung weight too, but not by a very significant amount. The calipers from the turbo/s2 help a great deal but you wouldn't have those unless the suspension came out of a turbo or an s2 obviously. Changing the wheelbearings is much harder in the rear, and a good bit harder in the front as well, details depending on exactly what you have. Like I said, I'd just leave your car alone. +You can sell parts of the suspension you do have now. Infact, do you have the caster bushings? (these go to the back of the front control arms).
Ahmet
Cheers!
Old 09-02-2003, 02:41 PM
I think I will keep what parts I have until I purchase a car. And I do have the wheels, brakes everything. Thanks for your comments.
JRW
1987 924S White
1971 914 Red
Old 09-03-2003, 09:00 PM
